Just eondering if anybody else is having the same battery percentage meter being displayed improperly?? Mine will say 100% all day until i do a reset on my phonr and then it will show the correct usually almost dead battery life level. I have tried enabling and disabling the show percentage meter in the options but will still show 100% everytime. Also the phone will say in the info panel,pull doen menu,battery full disconnect to save energy even when the usb or usb with charger is disconnected. It seems it gets stuck in the usb connection mofe and yes usb debugging is dusabled,have trued it while usb debugging is enabled as well with same results. Other than
