d.knight99
I know there are multiple widgets for showing battery percentage, but is there a way of showing it in the menu bar. Just like as an overlay of the battery icon? I don't see the need for a widget AND a menu item, plus it would be helpful to see it as a percentage at all times, without the need to exit to the homescreen during calls or using apps.
Thanks!
Thanks!
