Root Battery Problem.
wer
Member
Ive Been On Negalite Blurom for a long time. and since the radio update my battery has sucked. i took it off the charger at 99 percent. then 3 hours later bam. 37% and i havent done anything except for text. and my screen brightness has been all the way down. and everything accep for wifi and mobile network is off. and my 3d switch is off.
Go back to that battery screen and click on the Screen option that's using so much battery. It might give you a reason why or suggest what could help it. But this phone just uses a lot of battery anyways hence why so many ppl buy the extended battery.
Also does your screen look brighter then it normally does? The 3D switch is just for camera. The actual 3D in the screen can sometimes get stuck ON for unknown reasons. A reboot solves that. Try rebooting to recovery, go to Advanced, then choose Wipe Battery Stats. Reboot and charge your phone to 100%.
Did your phone get really hot? A similar thing happened to me a couple of weeks ago, and I haven't figured out what it was. Start reading here, and there's some on top of page 7 as well.
http://androidforums.com/evo-v-4g-a...ex-nova-aroma-03-17-2013-a-6.html#post5632975
I tried to get some answers to some questions, but never got anywhere. The main thing I want to know now is...since I had such a long stretch of sleep time while it was discharging so fast, could you even call it a wake-lock? From what I can tell, a wake-lock keeps the phone awake...and from the pictures, the phone wasn't actually awake for a long period of time. If anyone can specifically address this question, I'd appreciate it.
