Help Battery Recharge Issues
crackdroid1
Hey there. Anyone else having a problem with the Motorola Droid where the battery charges normally until it gets to 90% then stops? I am running NexBeast V1.1 on my DROID, if that helps. BatteryLife(By CurveFish, its a widget.) says the battery health is good.
EDIT: Nevermind. I discovered the part of the charger behind my bed was a little bit loose.
