Battery Remaining
ronjcar
Member
I am able to see how much of my phone is using the battery ie. display 50%, but I can't find what my total battery remaining is. How do I show that?
Ron
Vizbattery is a great battery widget I used that untill HTC came out with there own battery widget hope this helps
I use BatteryLife, it gives a graphical and numerical indicator of the remaining life (10% increments), as well as battery temp., condition and if it's charging.
I use Battery Left. Give it a week to calibrate. It's a pretty awesome widget. Tells you the percentage left in increments of 1% and also gives you time remaining on your battery
