androiduser96
Since the LG Esteem doesn't have the best battery life out there. I was considering using a battery saving app. I wonder though and I have q couple of questions: do they really work? or do they mess up your phone?
. Make sure you have an widget to disable data(since it's the biggest juice drinker) whenever you are not using it. Get "dataswitch" from market.2x battery works great. I get between 13-18 hours on the stock battery. (I did get 23+ hours once but I forgot my phone at the house so it sat there with zero use)
I just bought an extended battery.That did the trick.
After all. don't use a battery saver apps. You can simply apply the tweaks manually rather than leaving that app running which itself is wasting your phone's resources and tends to decrease battery life.
The biggest battery hog would be the data flow. What specific tweak is there to control that?
