Root Battery Saving Apps That work with Greenify
IHaveAnAndriod
We all know that the Nexus 5 has a horrible battery life Spain. It doesn't last long throughout the day. It is good for when you are a multitasker.
I have the greenify app for Android to close the apps that are running in the background this seems to be helping a little bit. But that just keeps the apps close I want to know if there is another at that I should be using while using the green app. Greenify seems that it doesn't do the full job. Are there other apps that I should use with it. I want to make my Nexus 5 battery last as long as I can throughout the day I keep my wifi and location service is off throughout the day and I keep the brightness turned down and I you 3G most of the day. The 3G does not affect me that much because I had Tmobile. The tmobile 3G network isn't that slow.
Does anyone know of any good tips or apps to help minimize the battery usage the day but still be able to use the phone?
