Hi guys,
Firstly im no expert, however I would like share my experiences and knowledge of battery saving tips. This is probably best suited to novices like myself and some maybe obvious.
Tip 1 :
Turn off wifi, GPS, Bluetooth - when not using it.
Tip 2 :
When connected to wifi, turn off mobile data
Tip 3 :
Turn off googles location service, unless you need latitude. - Settings - Location Services - Turn off all 4 boxes.
Tip 4 :
Dim screen brightness, I like to use a widget called brightness level, mainly keep brightness on 25%. Screen brightness is a big culprit for battery drain.
https://play.google.com/store/apps/...XJ2ZWZpc2gud2lkZ2V0cy5icmlnaHRuZXNzbGV2ZWwiXQ..
Tip 5 :
Disable apps you dont use, e.g. email and exchange servces. You can disable apps, by going into manage apps within settings.
Tip 6 :
Turn off backround data sync within apps. Apps such as Google currents, pulse etc, regulary download data in background, turn this off and manually download when you actually use the app.
Tip 7 :
If your a facebook user, uninstall the official facebook app as this is a big battery drainer, I prefer to use :
https://play.google.com/store/apps/...result#?t=W251bGwsMSwxLDEsImNvbS5rcm0uZmJtIl0.
Theres probably some more tips I've forgotten to add, but these are the main ones I follow.
Tip 1 :
Tip 2 :
Tip 3 :
Tip 4 :
Tip 5 :
Tip 6 :
Tip 7 :
