It's ****ed. This is a known problem and people shouldn't try rooting or flashing until this is fixed. You can flash this to get %1 battery (it only says 1%) and be able to use your phone. LT15i_3.0.1.A.0.146_Global.rar
there is a fix u have to delete a battery file in your root folder.. i had the problem, since no one on this goddamn forum tries to help ill searh what file it was.. ill let you know
oke..this is what i did with the downgraded arc..downloaded a program like root explorer and deleted the batterystats.bin file manually from data/system.Now reboot your phone! This worked for me..although i'm reading some comments of some people it didn't worked with , and i think they just didn't rebootted the phone..But it worked with me, the battery went normal but the the phone went "unroot".if you still want a rooted 2.3.4 withoud the battery issue ,try this method..2.3.4 Root (with locked bootloader) - xda-developers.
