Does anyone know how to reset battery stats? I had the link to it but can't seem to find it out. I can't remember if the post was here or over on xda either. Thanks!
You need to Boot to Recovery Mode. There is an advance setting option there that has Wipe Battery option. Since I have ROM Manger and a Custom ROM running my Advanced Option is found under ClockworkMod Options. The Wipe Battery Option may be listed differently on Stock Phone but it is in Recovery Menu.
