Menu, Settings, About Phone, Battery.
I made a custom widget that displays % battery remaining, which when I tap it goes directly to this screen.
"Up time" is how long it has been since you've rebooted (turned phone off & one), not necessarily how long it's been since you've been hooked up to a charger.
"Awake time" is how much you've actually been using the phone.
You may need a specific battery app for that. I recently deleted all my battery monitoring apps 'cause I wasn't using them. Too depressing.Thank You for the response, I have seen this option before, I have seen another one were it actually says since charged and displays the time.
Thank You, that's what I was looking for.Settings>about phone>Battery> Battery use
at the top it will tell you how long it has been since it was last unplugged.
