Mine finally ran down until it powered itself off. Apparently it only goes in increments of 10 until it hits 15, then 10, then 5...off. I'm charging it now. I just assumed it would give you a more accurate percentage.
I've also charged mine twice to 100% both times w/ wall charger. USB is REALLY slow. It's been plugged into my laptop usb port for about an hour and only moved from 10% to 20%. I should add that I've been adding a ton of music to the Atrix during that last hour so maybe that has something to do with the slow charge rate...just a thought and yet another thing to test tomorrow.
