when I first got my craptivate, I was pretty impressed with battery life. I got 7.5hrs of in-n-out of service, taking pics, playing a bit and it cost 15-20% of my battery. I played for 1hr solid and it took 10%. Not bad. I then had myself a marketplace orgy and downloaded a shit-load of apps figuring I would check them all out later. Most I knew I would want eventually. I think I found a bug in photobucket this way. I noticed my phone would *idle* using 10%/hr of battery. That is horrible. I found through process of elimination it was the photobucket app, and the battery usage? not cpu, no, it was the 3G radio. It was probably attempting to login (w/o credentials as I had not config'd it yet) repeatedly. Once I uninstalled it (it would auto-start even after being killed) my battery went back to staying almost flat while idle.
so far, photobucket (at least unconfigured) is a problem app for battery usage. everything else I've tried seems ok so far.
