Help Battery temperature indication
dano_mbg
Hey all!
I've used several apps in the past that show battery temperature e.g. circle battery widget, super battery even android tethering which has a dedicated icon for temperature. But none of them seems to be working. Temp stays at 0 degrees (celcius) even if the battery gets really warm. I've looked through the phone and the apps' settings but nothing. Is there a way to fix this?
It's not a huge problem but i'd like to get it working..:)
PS:I'm currently using CM7 v2.0M3 but even when i was running the stock lg 2.1 rom the same thing happened
That option only works on certain phones. I know for sure that it works on a HTC Wildfire, but it doesn't work on a GT540 unfortunately. :'(
