cortland1998
**Install at your own risk. I will not be held responsible for any damage to your phone!**
**Always make a Nandroid backup before installing these!**
Installation Instructions
- You MUST have sdk installed on your computer! HowTo
- Make sure USB Debugging is enabled!
- Plug your phone into the computer and run the EXE file
- Follow the instructions when prompted
I will be putting together a lot of different styles and posting them all here.
If you have any in mind or want some ported over let me know!
Also, I will be making these only for the ROMs I use. So, if you want it for a certain ROM let me know!
Simple Battery
Download Link
Blu Battery
Download Link
Gas Can
Download Link
Simple Battery
Download Link
Blu Battery
Download Link
Gas Can
Download Link
