Battery Time
apavolka
On my Eris I used battery time lite but when I installed it on my DX and realized it didn't update. It said I was at 30% but my low battery message came up. I've tried other apps similar but they only go by ten percent increments. Anyone know how to fix battery time or know a good free similar app that shows status in the notification bar?
Yes, but it's based on an estimate, so it isn't perfect.
Untrue.
There are two % measurements you can select.
One is the system battery % which matches all other battery percentages I've used. Then they have an estimate based on *your* usage pattern. That one is the estimate.
You can show one or both % on your widget and/or in your notification bar.
