Have you turned off your phone (not a shut down) for 5 mins or so and then turned it back on and checked your times, they should be different. If u have done that then some app is running in the background. My times are always different.
I noticed a similar problem I checked a couple of apps and it was as if they had been reset or something. Not loosing any settings but acting as if I just installed them. so I opened each app on the phone once to make sure they weren't in that state and my uptime/awaketime was different from that point on
