Help Battery Uptime/Awake Time
dpabraham
After upgrading to 2.3.3, the battery uptime/awake time stats do not update after shutting down or rebooting. This was not the case before upgrading. Took the phone to the Sprint store and they said the phone is working correctly. Any thoughts or suggestions would be greatly appreciated.
What do you mean by not updating? Do they stay at the same number, or is the uptime the same as awake time? Does anything change with a battery pull or charging your phone?
I think he means they do not reset to zero after turning the handset off. They used to reset in older versions of Android.
I actually like that they do not reset because it is easier to gauge what is consistently using the battery between charges even if you reboot your handset. To each his or her own, I suppose.
