Battery usage issue?
Wendimn
Just got mine yesterday. Charged all night and it died after about 4hrs??? Battery usage says 90% voice calls...4% display, 3% cell standby, 2% phone idle. It did completely die so maybe that will help. I have noticed that facebook usually takes a huge chunk of it..anyone else notice that??
How can you say usually when you just got it yesterday? :p
It all depends on settings. You can configure fb to consume alot less by just making it check for updates less frequently.. The less it needs to check, the less it needs to 'wake up'. If it doesn't wake then it litterally won't use any resources.
As for you battery life.. Make sure you fully charge your battery the first time and be sure to do that now just to be safe. Voice calls will always be a major battery drain tho. So if you have used voice calls for about 4 hours.. I think it's not unusual for your battery to be drained (dunno exactly, never call that long).
