tonyguy2000
Member
My battery life has been cut 50% since last weeks update with no other changes made on my phone. Has anyone else experienced this ? Thanks,
Did you open up the blockbuster app and start messing around with that?
I know for me i did as soon as i got the update and in turn it kept trying to update the video library and it was killing my battery. thats about the only thing i can think of that would of changed from the last update.
There's an option in the blockbuster seyour heloptting to quit it's constant updating. Forgot what the actual wording is. If that's that what your problem then is then I dont know. I'm guessing you didn't download any new apps since the update?
1. Sign back out of Gtalk
2. Make sure Enable always-on mobile data is unchecked
3. Check your Accounts & Syncs. Stocks are turned back on.
4. Disable all the options in the Blockbuster app.
5. If you don't use the stock News, News & Weather apps go into them and turn them off.
All of these above were turned back on after the update. It will help a little.
Is #1 something that you have to d/l? I cannot find it anywhere in applications, nor do I see it when I list out "Manage applications" or "Running Services" in Menu/Settings/Applications. I would think that if it is something that is a part of the OS, that it would be at least listed in the "Running Services" section. Please advise, as, I personally, have not been able to contain the excessive battery drain (since the update). All of the rest that you mentioned, I've already taken care of. Thanks.
Its just going to be listed as "Talk" inside the chat bubble.
Thanks for those other suggestions, I had already accomplished all of those that applied to me.He is right. If you are running an unrooted phone it should be under your all apps as "Talk". Go into it set the settings as do not auto login and sign out. That is if you don't use Gtalk.
Gtalk constantly checks for on and offline users in the background and has been known to be a battery drain since day one of launch. It is part of the OS.
A couple other things I did after the update to fix the issue because I couldn't contain it was this:
http://androidforums.com/evo-4g-support-troubleshooting/141369-how-fix-froyo.html
and
Battery problem, try this. - xda-developers
