I always see those 3. Why don't I see the other programs, thats using up the battery? I was able to see them, but not anymore. Its been like that for a while now. Any way to fix it?
that is the screen to let you know that the system is the main onee using most of your battery.
But it always shows those 3. I use FB, Twitter, browser etc. And it never shows those programs taking up battery life. Its not really a big deal, but it annoys me.
That's shows what "hardware" and system processes are taking up battery life. IE display, Android system, Bluetooth, calls, stand by. Not applications.
Download and install Android Assistant... it will show you everything using memory and battery, and give you the option to stop and FC any/all of them. You can also program it to ignore certain apps and/or widgets. I'm pretty sure it won't allow you to stop the system apps and processes required for android to run, so it'll be safe as far as that goes...
