Help Battery use widget
Alonzzo2
There's a battery use widget which is actually a shortcut to a menu (or a hidden menu, i didnt find it anyway) that shows the percentage of the battery that every process used.
It shows me:
Android System : 70%
Cell Standby : 14%
Phone Idle : 14%
Android OS : 2%
can anyone share his usage statistics? Im not sure if its normal.
anyway, no matter what i do to my phone - running 1.6.3.1 , with APN on, sync off, wifi off, gps off, wireless networks off, around 30 minutes of accessing the network and 30 minutes of calls - the battery almost dies at night.
u got the no-sleep Issue.
try rebooting the phone after unplugging it or after long calls..
the android system shouldnt get 70% of usage... its too high
So should this be my indication of the no sleep bug?
high percentage of the Android System? how much is high? >20%?
its not mathematical but its something like that, yes. depends on your usage of the phone, if u use the phone alot the percentage will be higher
I rebooted 13 minutes ago and it shows me:
Android System : 93%
Cell Standby : 4%
Phone Idle : 3%
in these 13 minutes i had a 10 seconds phone call, and thats it.
So im not sure its the no sleep bug...
i think you should wait longer than that...
but maybe you have any app that can cause that?
I think the app Spare parts > Battery history > Other usage > Running is a better indication.
and currently it shows 37% running .
I dont have lots of apps installed. maybe its feedr... im not sure.
