Im just curious... Im using the stock battery on my Lg esteem, and i want to know if its good having; phone idle 3% and cell stand by 6%. i silly question and post but i want to see how everyone elses battery uses are.
Based off the percentages, you are using your phone quite a bit. There is nothing wrong with the usage of your phone, thats the reason why you bought it (to use it). Those percentages will change based on how you use your phone and for how long you do so.
To make a long answer short, there is no real good/bad battery usage unless one usage is engulfing your battery in which you may need a replacement.
But is that bad? having that amount of usage (cell stand by and phone idle) without using it that much. i want to know what i should be getting without that much of use. i know everyone is different with their phones but i want to know what i should be getting.
