Battery Widget from HTC
lnnelson
Hi,
I accidently deleted the HTC Battery Widget that came with the phone (HTC Thunderbolt). I was unable to find another copy of the widget to download in any of the market places. I called HTC, and they stated the only way to get the widget back is to do a hard reset. I know these things are usually available on the internet somewhere (I found an earlier version of the same widget (com.htc.rosiewidgets.battery), but have been unable to find the most current one. Any help in the right direction would be greatly appreciated.
Do a long press then select "Get more htc widgets" there is a battery widget there. If you're talking about the one in the status bar then you may have to do what they say.
I should have been more specific. I uninstalled it from settings under the applications. The long press method described did not work. Any ideas of how to get another copy or recover what I lost?
