Help Battery will not charge and I
swoot
Hi all
Been abroad (Spain) for a week with no issues, battery has been charging fine. Couple of days ago noticed that battery was discharging very quickly (Android OS was main cause in battery settings screen). Now with only 12% left, the battery is failing to charge altogether (I
Update: tried charging again last night, battery charged upto 74% then stopped charging, so looks like the port is OK. I
Power the handset off, remove the battery for 5-10mins, replace, then try charging.
As far as recovering photos, videos etc, if you have an external memory card installed simply copy everything to that. If not then your best solution is using Dropbox, Google Drive etc - find a nice bar or cafe with wifi access.
