The funny thing is I already did that. The second battery is just as bad as the first. It's getting really annoying have to keep my phone plugged into the charger.
I recently installed a battery widget that required calibrating to report accurately battery life left. To do this you had to fully charge the battery, and then let it completely discharge. I don't use this phone as a laptop. I make calls, check and write email, occasionally surf the web, send and receive text messages. Time from fully charged to when the phone FINALLY shut off due to battery discharge was an incredible 52 hours...yep had it on, used and didn't charge it from Fri morning till Sun afternoon. I for one won't complain about battery life with this phone.
What widget is it called, did you get it from the market?
It's called "Battery Left", I think I got it from the market. Maybe just a Google search, but it's here, and it's free.
I'll give you some of my settings. I was getting 6 hours to the charge with little to no use. After I used these new settings I got 20 hours(still 10% left), and I watched Kick Ass(full movie), some music, wireless tethering(hour or 2), apps, web browsing, etc. I did a Bluetooth File Transfer for movie too.
Sound & Display:
Volumes: Max
Animation: Some
Brightness: 0
Screen Timeout: 1 minute
Regular Wallpaper(no live)
Data Manager->Data Delivery->Email and Corporate Sync:
Email Delivery
Data Push: Disabled
Fetch Schedule: 4 hours
Sync over Wi-Fi: Enabled(when you open app it'll look for new emails)
Social Applications:
Sync over Wif only: Enabled
GPS: Enabled
Application->Development
Stay Awake: Enabled(Screen doesn't turn off while charging)
Battery Manager:
Smart Mode
Off-Peak Hours
1:00am-9:20am
Data Timeout:
15 mins
Peak Hours
Data Timeout: Never(you can change this)
Auto-Bright: 0
Those are my settings. After, I switched I went from 6 hours of Battery Life to over 20 hours.
