Help battery
northernale1
ok this morning as i was using the x10 to web surf with wifi and plugged into wall charger,, the battery level was decreasing, i find this unusual as my old iphone3g would charge while usung it plugged in,,,
is this normal for the x10???
The X10 naturally decharges when plugged in
Once it hits 100% it is known to switch off the charge and use battery power rather than mains, some have reported anything from 75% upover till it recharges again
So depending on what levels it was at when you noticed it, yes it can be normal
was at 83% when I plugged it in,, down to 72% and green light in corner was on whole time,, and also was the charging icon,, but they may just be on when ever plugged in,,,
I experienced something similar, but my battery had died, so I plugged the charger in and left it for 5 minutes before I used it, then when I tried using it, the battery died again, even tho the charger was plugged in
