:thumbup:Sounds to me like you have a wakelock that is keeping your phone awake when it should be in a deep sleep.Some apps do not dismiss this wakelock when shutdown.If you can go to your battery use option in settings and click where it shows the time on battery.A graph should open.See if your Awake and Screen on look almost the same.If possible post a screen shot.
well you have to find whats causing the wake lock.I know a few apps that will cause this off the back of my head like Power amp if the some of the headset options are enabled (disconnect-stop,connect-play) or if the license is not verified it keeps trying.GoSms if you are logged into GoChat.Talk by google(uninstalled)
Another thing try downloading betterbatterstats : http://forum.xda-developers.com/showthread.php?t=1179809
That better battery stats thing is over my head. Do I just install it and it tells me what is causing the wake locks and how to fix?
Can anyone tell what's the problem here
do me a favor,grab me some screenshots of the kernel wakelocks,partial wakelocks and alarms.All of them from the "since unplugged" option.
I want to see what can be causing it.another thing you can do is use the "dump to file" option by hitting the menu key and then selecting more then dump to file.
