Help BattStatt FC
OK I really would like to use the BattStatt widget for the nice clean look. I downloaded it from the market and when I go to add it to a screen I get the configuration screen and then when I hit the home button it force closes and sends me to the homescreen. I have uninstalled and reinstalled several times. Even found and tried a previous version with no luck. I am at a loss. I am also having the same problem with Tajm. All other battery widgets I have tried work fine.
I am running stock with LPP. Any ideas or thoughts.
Hmmm...
Sounds like a developer issue to me.
Try shooting the dev. of LPP and BattStatt emails explaining your issue. (PS: I know the dev. of LPP doesn't like emails, so you might wanna post on his forum about it: LauncherPro )
All the best,
Eric
As fas as Tajm goes, I've tried it on mine and I use LPP and it doesn't have problems (Other than the occasional time-lag).
OK I figured it out. It was a newb mistake I was pushing the home button when I should have been hitting the back button when I was done on the config screen.
