BBV0.4 1GHz Kernel Choice
Ok, So I am rooted and running BBV0.4 Rom and everything is great. So of course I have to try to make it better. I am looking for 1GHz kernels that work well with BBV0.4. I have seen several options in ROM Manager, but was looking for some factual data and not just fancy names.
Also I am not that familiar with the ROM Manager app, so if any one has a link or a list of steps that I can expect when updating a kernel via ROM Manager it would be greatly appreciated. I didn't see much in the way of a users guide on the Devs website.
Thanks!!
Thanks!!
BB .4 already comes clocked at 800Mhz oc, you can try chevys kernels, but i find any other kernels tend to make the rom unstable
I know you said you didn't want just names, but I'm running the P3 low voltage 1100-250 kernel. It's 1.1ghz, but there are 1ghz too. It's got intervals (7slots) and the min. is 250. I went with the low voltage to see if my battery life would change or at least stay the same while OC'ing the processor. I've been running this for about 1.5weeks and it's very stable and quick. The battery life is the same as with the 800 that came with BBv.4, but it's quicker (obviously). My quadrant scores with the 1.1 P3 have been around 1400+, while with the kernel in the BB rom it was around 1000-1100.
http://p3designs.info/kernels/
I had been running the default kernel in BB .4 for a couple weeks. Switched to Chevy ULV 1.1 last night and all is working well.
Thanks Jeff_t and Takeshi, that's what I was looking for. The more popular kernels folks have used successfully. Each processor can be slightly different. I was looking for kernels that were proven to have worked well with BBV0.4, so that as I take the incremental steps towards 1.2MHz, I could have some level of comfort that if it failed, and I had to back out, it was most likely because I had reached the limits of my CPU, and not because of a kernel issue.
Thanks again!!
cyberclaus...I've been using BB 0.4 for a couple of days with P3 1.25ghz kernal. Set to max 1.25ghz and min 250mhz. Works well, and stable on mine.
