Root BCM CM9 ICS Rom False Roaming Indicator Fix
Mr Derp
ROM: BCM Cyanogenmod 9 Ice Cream Sandwich for GSM and CDMA phones
Device: HTC Desire CDMA
Provider: Us Cellular
This is to fix the false roaming indicator icon while using BCM Cyanogenmod 9 ICS rom on the HTC Desire CDMA for Us Cellular.
I didn't come up with this, but liamf1 helped me fix mine (as seen in the posts below), so if you are going to thank anyone, thank him. (Go down to his post, post number 6, and click the thanks button below it to the right.)
First, before we begin, lets see if you are actually roaming or not... Go to Menu > System Settings > About Phone > Status, scroll down to where it says "Roaming" if it says "Not Roaming" underneath it, then proceed to follow these directions.
Needed:
A File Explorer/Manager: ES File Explorer or Root Browser
I used Root Browser, because I couldn't get ES File Explorer to work on my phone. It worked like a charm. They can be found in the Google Play Store.
A Text Editor: Jota Text Editor It can be found in the Google Play Store.
Thank liamf1 for posting these directions.
Directions:
01: Download a text editor.
(Jota Text Editor)
02: Download a file manager like root explorer.
(ES File Explorer or Root Browser)
03: Head over to http://dl.dropbox.com/u/30169771/eri.xml (from your phone).
04: Highlight text from eri.xml and copy to clipboard.
05: Open text editor and paste text from eri.xml into a new document.
06: Save as eri.xml
07: Open ES Root Explorer, or Root Browser.
08: Mount as R/W
(If on Root Browser, you don't have to do this, at least I didn't anyway.)
09: Find the eri.xml that you just created.
10: Select move from the menu.
11: Move eri.xml to phone/data/
12: Reboot to make changes take effect.
(Wait a minute or two, mine didn't take effect for about a minute. If it doesn't do it this time, try rebooting again.)
If done correctly, you should see this: :D
My original post. :)
Hey guys, i flashed Bcm cm9 ics GSM/cdma rom and everything went great and I'm loving it, but it shows the roaming icon and on the notification bar it says roaming indicator on, but when I go to settings under roaming it says not roaming... so am I roaming, or not?
Fixed thanks to liamf1, if this helped you too, thank him!
liamf1 said: 01. Download a text editor. 02. Download a file manager like root explorer. 03. Head over to http://dl.dropbox.com/u/30169771/eri.xml (from your phone). 04. Highlight text from eri.xml and copy to clipboard. 05. Open text editor and paste text from eri.xml into a new document. 06. Save as eri.xml 07. Open root explorer. 08. Mount as R/W 09. Find the eri.xml that you just created. 10. Select move from the menu. 11. Move eri.xml to phone/data/12. Reboot to make changes take effect.
Thanks!!!
Device: HTC desire CDMA
Network Provider: US Cellular
Rom: Bcm Ics cm9 rom
Roaming Mode: Home only
I see "roaming indicator on" in the lock screen and status bar, I also see the roaming icon. When I go Menu > System Settings > About Phone > Status, under network it says "roaming indicator on", but under roaming it says "not roaming."
So I guess I'm not roaming?
__________________________________________________ ___
*** THIS WAS POSTED ORIGINALLY BY zoodski on forum.teamuscellular.com***
**ORIGINAL LINK Team US Cellular • View topic - BravoC users: ICS is upon us.****
Omg! Thanks!!! It worked beautifully!! It now says us cellular under network and I have a 3g icon!!! That should be put on his first post. Thank you so much man, its staying as my daily from. :) :D
Youre welcome!
I hope you have a great time in our Android forums community!
-Sincerely,
Liam-
Is there anyone that can point me in the right direction to download the ICS rom for my HTC Desire. Also is it a stable rom yet?
Thanks
Phil
Thanks
Phil
No, this is not a stable release, there are still issues, with camera and USB tethering I believe, I've also noticed that the browser crashes quite frequently. But I've been using this rom as my daily rom ever since I downloaded and first flashed it. It is amazingly smooth! I highly recommend it. :thumbup:
Sent from my HTC Desire CDMA using Tapatalk 2 Beta-5
it's five in the morning right now. So I must be missing something. But how do you get this to work for CDMA? It looks like it's a GSM rom.
Ok, so don'e mean to gravedig or anything, but I have the htc v one and I am sooooo happy I found this, it worked for that, all I did was change US cellular to Virgin Mobile :)
