APOPHiS420
ill check my port and tell you as I'm not home atm but I have managed to change it. Unless someone beats me to it of course lol
Hey, I'm wanting to do some more tweaking on this theme but I can't find where/which file the blue notification dropdown bar is located.. I've checked framework, settings, system ui, and can't seem to find it on this phone after JB update.. Any help would be awesome to improve this Theme and other themes in the future. Thanks in advance! :thumbup:
U want the TRUTH or the "story?" Can't get my Linux PC to do much cuz it's not Windows.
Just don't let ignorance get in the way of fact...Linux is a more than capable os
7-zip and Photoshop on Windoze = Fileroller and Gimp on linux. Hope it helps you out.
I have Gimp... And it's kicking my @$$, lol. Just recently got the p7zip stuff too and I use Wine to run it.. Pretty awesome program! Thanx bro! :beer:
wine...BOOOOO lol
Try xarchiver if fileroller doesn't work for you. Always better to use native apps if possible and it certainly is in this case
edit: fyi, p7zip is a command line tool
I have Gimp... And it's kicking my @$$, lol. Just recently got the p7zip stuff too and I use Wine to run it.. Still learning to use Linux. It'll take me a while to get used to it but, Pretty awesome program! Thanx bro! :beer:
Thank you.
sudo apt-get xarchiver ?
sudo apt-get install xarchiver
without Wine I wouldn't have Diablo III. Or Netflix.
Wine has its uses, but if you can do something with a native app you should. Better performance, less likely to get errors, etc.
Fortunately I'm not using boat browser thanks to SuperR. Got the link to download but after wiping cache and dalvik cache I tried installing and won't work. Says installation aborted can't open file (bad) what other browser should I use or is it the link
wine...BOOOOO lol
Thanks a bunch, just got the xarchiver and it rocks! One question tho... I have the ability to see the permissions for the APKs within the zip, but don't know how to change them in/out the zip file on my PC.. Any clues?
