beats audio
admob
Just a quick question, does beats only work with HTC music, I prefer playerpro but it doesn't seems to work, which is a shame as I really rate it higher than the stock player.... cheers.
Not really sure, I can't seem to tell the difference, you can use the Beats Audio through PlayerPro but I can never tell if it's working or not, can't tell the difference between the Stock music player and PlayerPro with and without Beats Audio.
Might just be me being deaf though ;)
the beats icon and ability to turn on and off doesnt appear with playerpro, you can however use normal headphones, and you can turn beats on, or have 'htc advanced' sound.... strangely enough....
Apparently HTC haven't released the Beats API yet so it's only available in HTC music player only at the moment
