Root Beats for CM9
install zip from sd..and start jamming like dr dre..lol jk
does the music actually sound better though?
you know what, its not an actual difference u can be like oh shit it sounds diffrenent but yeaah if you put on some headphones the bass sounds a bit better... Try it out... I just did it cause i was trying to learn how to zip a file... I thought it didnt even work to be quite honest with you
