Rhonen
I was surprised when I checked as other days, it seems beautiful widgets is at the bottom, usually 3%.
It looks like the GPS is hogging most of the battery at 1-1/2 hrs (am I reading that right?)
I don't know if it makes a difference, but I started using airplane mode when I'm in the subway underground as I have no reception.
In my settings, under location, I have it turned on and use gps satellites turned on.
Under beautiful widget small home, I had geolocation turned on. I turned it off. Will this help with the battery, or do I have to turn location off, too?
If I turn off location, will maps/navigation still work?
