Yeh I'm disappointed in this. I want an animated widget like HTC has. Even my jailbroken iPhone has an awesome animated, and accurate, weather widget. Beautiful widgets isn't even accurate for conditions (storming like crazy outside and it says partly cloudy)Any updates....I'd like to see the weather animation work similar to the way it did on HD2... I want the animated weather to run on top of my current home screen
Hmm i'll have to try it again maybe, I did that and all it did was for example at night, the moon would pop up and that was it, no clouds moving, or rain etc like HTC has or the widget on my iPhone has.It does show the weather animations if you enable it. Home Settings - Advanced -> Check "Unlock Animations".
And you can switch it between google and accuweather. I believe the htc default uses google, could be wrong on that though. Mine is always accurate as long as I update it. It doesn't always update unless you have it set to, but that drains battery pretty quick.
