bunnisher
Member
I've just purchased BW and upon initial set up, it gives the pop up about downloading animations. When I click 'okay' it just sits on 0%. The longest I've left it to keep trying is 5 min before I hit cancel.
I then try to look at the skins. I press the download skins tabs, the wheel thing spins for a bit and when it stops, there are no skins.
I've tried rebooting several times. My wi-fi is on and working fine. I've got about 20mb free on international memory.
I've searched this forum and found one person with similar problem but no solution was posted.
The app description does say they are working on skin server issues but I didn't realize the problem could be as big as not being able to access any skins at all.
Am I doing something wrong or is it genuinely a server problem. Those of you with BW, are you able to get new skins?
Thanks in advance.
Thanks in advance.
