Beautiful Widgets, Droid, Notification Bar
I was wondering if anyone has had the notification icon for weather from Beautiful Widgets disappear?
I love the look and animations of the Beautiful Widgets with GDE and I also have the White Hero Theme - looks great. But now there is no Icon for beautiful widgets in the notification bar, even after I switched the setting numerous times. Anyone else?
Also I did a search on this and couldn't find anything.
Thanks
Nope, never had that problem. I use DXtop home though, when did you notice it missing? If it was after changing themes, try changing back and see if that fixes it.
Thanks but it seemed to work fine until this morning, it also doesn't seem to update the weather also, the temp stayed the same all day. I wonder if it has to do with GPS in my building...thanks for the replies though.
I've had this problem for a few days now, after a reboot it will disappear and I have to open the settings, deselect the notification check, and reselect it, and a few minutes later it will reappear. Hopefully this is fixed soon.
