therealciviczc
Member
Is anyone else having a problem with Beautiful Widgets smaller home weather after the last update? I noticed on my wife's ally, when you'd go to landscape, the widget does not fill the screen end to end like it used to. It cuts off about 1/2" from each side of the screen. I have an ally also and mine goes end to end. I'm still using an older version of Beautiful Widgets though. I reverted hers back to an older version and it works like mine, going end to end, as it should. I see in the release notes on the newest release that they 'fixed' a landscape bug on smaller home weather, but it seems their fix made it not work correctly on the ally. I can't seem to find any way to contact them about this.
To elaborate on my already long post, I'm using launcher pro plus, and when I highlight the widget to resize, the highlighted box DOES go end to end. The widget does not. WTF? Is it a skin issue maybe? Something is weird.
