Help Beautiful Widgets
I have it running as my main clock/ weather app. Runs great. Love the variety of skins.
I dont use any of the other widgets at the moment though.
How do I pull a screenshot?
'shoot me' is an app that allows you to take screen shots, however you do need to root. But what with all the one click roots out there it's a cakewalk man.
If you hold down the back button for few secs, then push home button, it will make a click noise and a screenshot has been made. You can find the snaps at /sdcard/ScreenCapture
I'm running beta Froyo though, don't know if the trick works under Eclair...
Sorry for taking so long to post the pic, I totally forgot about it till today!
I think that is just a setting in beautiful widgets. If you tap the weather to bring up the forecast then hit the settings button then tap configure I think you can find the setting there. It's called temperature notification or something.
Yes is beautiful widgets setting.
Weather bug also does it.
I have weatherbug and can not find how to change the color on the task bar.
Black on black is not easy to see.
I might try Beautiful Widgets if I can not get it a different color.
thanks Kevin
I found the setting under the application settings for weather bug... much better with white font color.
thanks everyone.
Kevin
