Help Beeping trouble
It seems whenever I call someone, out of nowhere it gets this loud high pitched beep thats killer on the ears, its not right at beginning of call but somewhere around 2 minutes into it. Anyone else experiencing this issue? I'm tempted to call Verizon but I can upgrade in september and I don't know how good calling them will do.
That beep during calls could be caused by several different things, some simple and embarrassingly easy to remedy ;):
Do you have call waiting? If so, the notification beep for that might be set too high for you (easily tested, as you'll have a missed call ;)).
Is it happening with just one person you're calling? If so, it could be just them accidentally pressing a key during the call, if it's not a cell phone you are dialing to.
Also, sometimes a brief feedback loop can happen if the receiving volume is too high on your device.
If the volume button on your device is being accidentally pressed during a call, a loud beep can come into the speaker, also. Some users have reported accidentally holding the volume down button to the point of it automatically indexing up, causing a loud beep.
You'll need to think through all the possibilities, because it is very doubtful that it is caused by the carrier.
K, thank you, well the other person that calls me is using an original droid but using bluetooth calling thats with his car and rarely charges it, Im not sure about calling anyone else because I rarely call anyone anymore :P there seems to be no missed call when I look and I hold my phone towards the bottom. Ill try also to test volume and see if this is a factor. Thank you so much :)
