Look for a used Asus Transformer on ebay, should be able to pick one up for decent price and it's so much better than most of the cheap tablets out there.
To the OP, suggest you avoid buying a brand that you've never heard of directly from China. Often more trouble than they're worth, most are not really the bargains they're supposed to be.
I certainly concur with Shocky's suggestion of the Transformer Prime.
The original Asus Transformer is still a very good Tablet and has come down in price a little, also allot of owners trying to shift them because they've bought the Prime.
Just as a word of caution, many of us with the original T101 have been having issues with ICS. While the latest update from Asus has lessened the problems considerably, they still are there, so while the price may be right, it doesn't come without at least a few issues.
That said, I'd still recommend the original Transformer as a very fine tablet.
