I would like to know the best overall 2.2 rom there is for the eris, i know a lot of them are buggy but i heard some were decent..
There is no quintessential 2.2 rom.
This. Each has its own strengths and weaknesses.
I've tried a few, and I'd rank them as such:
Nonsensikal 12.5 (Black/blue) - Very fast and smooth (though not perfect, waking up can be slow and I'm still wrestling with the notification bar text). I'm sticking with this one for a while.
Kaos v38 - Fairly fast, some FCs, camera and gallery don't work well.
CELB - Slow, lots of FCs, I really didn't give this one much of a shot before moving on to Nonsensikal due to problems.
YMMV. xtrROM, while not froyo, is faster and smoother than any 2.2 rom I've found yet, and I would have stuck with that one if the texting were as good as froyo.
I'm using Kaosfroyo v37 and I can't keep a browser open. Any rom suggestions? Or other suggestions?
I use the Jorte calendar widget. It's 4x3 (all the way across and 3 rows down) then a click anywhere on it will make it be FULL screen.
Thinking xtrROM with Launcher Pro Plus. Or will I lose Flash? so I should use xtrSense?I'm totally confused now.Thinking xtrROM with Launcher Pro Plus. Or will I lose Flash? so I should use xtrSense?
