Best Backup Solution?
B2L
Android Expert
So I have been using Titanium Backup Pro for over a year now, and have tried My Backup Pro before that. But I just wanted to get some feedback and see what users around here use to backup apps and data, when flashing a new rom.
Any suggestions? Or is Titanium Backup still the absolute best?
I tried both and like TB as it's more detailed. My Backup Pro simply does one big zip file of your apps/data but if you only want certain apps to install, than you would have to uninstall the apps you don't want. I do use my backup pro to back up everything other than the apps.
That's what I had found as well. :) Both are great applications, but each work better in their own way.
Btw congrats on hitting 9K Roze. :)
I have been using app extractor lately. It is able to pull apps and settings right out of my nandroid backup. Since the nandroid includes everything and I do one before any risky changes, I don't have to worry that I forgot to back something up. It also does a good job with SMS / MMS.
