best battery app/ widget?!
Nothing that estimates battery time left is accurate because it has to guess how you will be using your phone.
Specific battery percentage can be achieved by many widgets. personally I like BattStatt cause its worded.
When you say voltage, what do you mean? The voltage capacity of the battery at the present level of charge (as in what it says in the battery info in about phone)?
Or how much Draw is taken from the battery. If the latter, Current widget is good.
*#*#4636#*#*
tap that into your phone as if you're dialling a number, it will take you to a battery info screen
Had Mini Info for a long time - its pretty cool and gives you a nice widget. Now trying Widgetsoid - and I'm very impressed. Gives you either a horizontal or vertical widget bar which you can load up with whatever you like - wifi on/ off, bluetooth on/ off, internal memory left as well as battery percent left. Loads and loads of options. You can also have it transparent with short indicators so you see the wallpaper through it.
I really like battery left, its free and you can customise it :) the widget is cool as well :) you can tell it to show temps voltage ect on the widget its self...
*#*#4636#*#*
That info screen happens to be where most widgets get their data from to display in the widget, so it's the same info. I use it myself instead of a widget, and if you use the recent apps shortcut (press & hold Home key for about a second), it will let you go back into the battery info screen quickly and easily. The only caveat is that the recent apps list only shows the last 8 apps, so you need to use it often enough that you don't have to type it in again.
