Help Best Battery App
Sabresfan2630
Does anybody have a battery app that they use on the MT to extend and monitor their battery?
On days that I dont have school or work I almost go through 2 fully charges. On days I do have work or school I can just bearly get through with 1 full charge.
I am in need a app that will help with my battery life.
Try out Juice Defender, and if you like it (and are willing to pay) get Juice Defender Ultimate. Hope this helps :)
I've been using easy battery saver.. getting a good 8 hours or so extra... Just install it and set it to intelligent, that's it
Has anyone used easy battery saver with miui?
its decent. i don't use battery apps anymore since it runs in background therefore draining battery. i just put it in airplane mode(or turn off data/wifi if I'm not using it). just 1% battery drain per hr or maybe less
I use juice defender. The free version is missing a lot of nifty features but does what I need it to do. I imagine the paid version would be much better.
