i am having an awesome time with buttered toast kernels.
just having the option to max it out to 1.7ghz dual core, to throttle it down to several steps in between.
If you know how to use kernel tuner, buttered toast is the way to go. IMO.
now if i can just convince one of my buddies to make widgets to quick switch the clock of the cpu, i would be good as gold.
also, not in my opinion really, but sorta fact.
buttered toast has the capability to out preform better then any i have seen.
or for better battery life, match or under volt as you wish.
