tispectrum
Member
that is because it isn't an application it functions as a widget only. add it to one of your desktops.
Thanks. big widget, doesn't fit on my home page.
It's a heck of a lot easier to open the voice dialer and say 'battery info'.![]()
I use "Battery Status" by Monmonja. It adds an icon in the status bar with with the percentage on it. I'd prefer it to "replace" the default battery icon, so that I don't have two... but its not a big deal. It works really well, and seems very accurate. I tried out 2 or 3, and like this one the best so far.
HTC battery widget works great and its free from the market !!!
You can also change the font size of the percentage number it shows you, which is great for us older Baby Boomers !
