I just FR my Incredible to try to improve the battery life, and the battery widget I used to have by HTC Corporation is no longer in the Market! Does anyone else have suggestions for the best widget they've found? I liked the HTC widget because you could see more details when you clicked the icon as well as the relatively small icon size.
Also, is it really better to not install Advanced Task Killer??
Thanks!
Thanks!
