does anybody know the best settings for this phone to take crystal clear photos, its kind of a big deal for me since i use it as my personal camera + use instagram alot.
Only thing I really do is set the focus to manual. I noticed that doing that also helps remove most/all the lag between pressing the button and the picture actually being taken, since it doesn't have to focus. For me, this removes blurs from moving the phone at the last minute (shaky hands)
Works fine for me, slide the focus bar (the bar on the bottom after you turn on manual) to the far right, that usually makes them clear. Might have to play with it a little bit depending on the situation.
